Mx Questions
COW Forums : RED Camera
Anthony DeRose
Mx Questions
on Jun 2, 2010 at 4:55:07 pm
I have some questions about the new MX sensor.
1. What is the best ISO to shoot with? It seems 800 gives the most DR and protects highlights. At the same time however that would mean a lot of ND for shooting outside. Also 800 would be underexposing the RAW but a stop as it seems the native RAW file is 400.
2. If 800 is the best how is the camera with IR light? I know they fixed the issue though is it still strong once you put in ND heavier than 1.2? Or once your past 1.2 or stacking up ND is it good to throw in a hot mirror or use one of the IRND combos?
3. I am a little confused about Redview, is that the new monitor viewing setup? So instead of Rec709 or Redspace you use Redview?
I haven't used the new sensor and when I do plan on doing test. It seems the MX offers a lot of new options prior to the first sensor. I am just used to keeping it at 320 for best results and viewing in Rec709 but that seems to have changed a bit.
http://www.anthonyderose.com
David Battistella
Re: Mx Questions
on Jun 2, 2010 at 8:17:54 pm
Anthony,
Some of this is covered in an updated COW article I just finished up on exposing the RED M-X.
The sensor is still rated at 320 ISO, you can move it higher with much less noise. The sensor is NOT faster, it just has a much cleaner noise floor.
It is not called REDVIEW
It is called REDCOLOR and it is the new RED Color science.
You will notice that RAW and REDCOLOR views are not too different from each other.
REC 709 is gone in the new build.
David
Peace
Anthony DeRose
Re: Mx Questions
on Jun 3, 2010 at 1:06:59 am
Thank you! Where can I find the article?
David Battistella
Re: Mx Questions
on Jun 3, 2010 at 1:29:06 am
http://library.creativecow.net/articles/battistella_david/RED_camera_Exposu...
The new one should be up later today.
David
Peace
Anthony DeRose
Re: Mx Questions
on Jun 3, 2010 at 3:41:02 pm
Haha awesome, thank you! I have had this bookmarked since the first time I used the RED didn't realize that was the article being updated.
Cheers
David Battistella
Re: Mx Questions
on Jun 3, 2010 at 3:49:41 pm
Here is the link to the new article.
David
http://library.creativecow.net/battistella_david/RED-MX/1
Peace
