Using MX clips in Color
COW Forums : RED Camera
Dan Hayes
on Apr 14, 2010 at 9:56:25 am
Hi All
I've got a FCP edit coming up that is going to be shot on MX camera. I understand the color science has been changed, will Color have any issues dealing with the R3D files generated?
Dan
Russell Lasson
Re: Using MX clips in Color
on Apr 15, 2010 at 5:39:53 am
[Dan Hayes] " I understand the color science has been changed, will Color have any issues dealing with the R3D files generated? "
I haven't tried it, but it will likely have issues. Other programs have all had updates for MX footage. You don't know until you try though.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net
David Battistella
on Apr 16, 2010 at 3:58:08 am
Answered in the REDUSER forum.
David
Peace
Russell Lasson
on Apr 17, 2010 at 12:44:20 am
What was the answer? (This is me being lazy instead of trying to tackle a search in REDUSER.)
-Russ
Russell Lasson
Color Mill
Salt Lake City, UT
Illya Laney
on Apr 17, 2010 at 2:05:55 am
I don't think Color supports MX yet.
Motion Design, Color, Editing
Simulated Wood Grain Cabinet Inc.
(Seriously though, that's the name on the paycheck)
David Battistella
on Apr 17, 2010 at 3:38:00 am
[Illya Laney] "I don't think Color supports MX yet. "
Absolutely wrong.
http://reduser.net/forum/showthread.php?t=43820
main contents:
If you use the new Color framework, which is in a thread by RED's Rob Lohman here on reduser, then you can handle any M-X footage.
I believe there is also limited support for 4.5 K in COlor as well.
David
Release notes:
Added support for the new Mysterium-X sensor
Added support for the new FLUTâ„¢ color science. This plugin will only do the new color science. If you need to use old color science with an existing project you should not upgrade to this version of the plugin or restore an older version when you switch back to an old project.
Added support for the new REDgamma gamma space and REDcolor color space
Added support for 4.5K footage. Clips recorded at 4.5K (4480 x 1920) will load as if they were shot with a resolution of 2240 x 960 due to Apple Color being limited to 4K maximum resolution. Half resolution decodes for 4.5K footage will not go through any debayer.
ISO list does not go beyond ISO 2000. Any clips shot at a higher ISO will be clamped to ISO 2000
Mac OS X 10.4 (Tiger) is no longer supported with this release
Peace
Illya Laney
on Apr 17, 2010 at 4:49:54 am
Thank you for enlightening me.
David Battistella
on Apr 17, 2010 at 5:02:31 am
No problem.
I know it can be difficult to stay on top of what is going on. (because so much is going on)
David
Peace
Russell Lasson
on Apr 20, 2010 at 6:55:31 am
[David Battistella] "No problem.
David "
It only changes like once a week:)
-Russ
Russell Lasson
Color Mill
Salt Lake City, UT
