Ideas for RED audio workflow
COW Forums : RED Camera
Rinny Wilson
on Apr 11, 2010 at 3:02:15 am
I'm currently working on a film where the audio is being recorded separately from the red footage. I'm the assistant editor, so I need to sync dailies. Normally, we edit with proxies in FCP and then send an EDL through wiretap to Smoke. How can I sync and keep to this basic blueprint, or at least still be able to finish in 4K? Thanks!
Russell Lasson
Re: Ideas for RED audio workflow
on Apr 11, 2010 at 5:09:59 am
A merged clip should still work fine. Video timecode and reel name wouldn't change. You should test it.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net
Noah Kadner
on Apr 11, 2010 at 4:57:40 pm
What does the audio mixer(s) need? Typically I'd just run out an SD mixdown of video(they often just ask for DV) along with an OMF of the audio and make sure I switch off the lights on my way out of the office.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Rinny Wilson
on Apr 12, 2010 at 12:52:35 am
I'm a bit of a newbie, so I'm not completely sure what you mean by a merged clip. I'm especially unfamiliar with red, so I really don't know how to easily merge the proxies with synced audio.
Also, the audio mixers need an OMF and the original audio files, but I'm just trying to figure out how to make this easy for the editor.
Jesse Glucksman
on Apr 12, 2010 at 2:32:07 am
I just learned about merging clips yesterday. I'm new to RED, on-set data wrangling for the first time. Pretty much, import the audio and one of the proxy video files to FCP and do a Mark In at a convenient synch point (the clapper may appear an obvious choice). Then select both clips, right click and choose the 'Merge Clips' option. Self-explanatory from there.
Rinny Wilson
on Apr 13, 2010 at 12:51:04 am
Thank you! I'll try this.
