Cropping w/ Color softening solution?
COW Forums : RED Camera
Brandon Adams
on Dec 30, 2009 at 10:14:03 pm
I'm editing a piece shot at 4KHD for 720P output. Some of the shots I need to crop/zoom 150%. I'm getting bad results from Color, and this article http://provideocoalition.com/index.php/awilt/story/redfcpcolor_making_it_al... (and other things I have read) says it has to do with how Color sharpens and decodes the RED file.
I can't think of a good workaround, other than exporting full frame from Color at 4K ProRes. Does anyone have any suggestions?
-Brandon
David Battistella
Re: Cropping w/ Color softening solution?
on Dec 30, 2009 at 11:12:56 pm
WHy not relink the full frame r3d's in the FCP timeline and do teh blowup from the F proxy in Final Cut Pro (assuming you are working with FCS 3)
David
Peace
Brandon Adams
on Dec 30, 2009 at 11:17:08 pm
That's what I'm doing currently. But if I do the blowup in FCP, then send to Color, Color references the R3D and applies the FCP basic motion blow up in it's "Geometry." Thus the cropping is done in Color.
-Brandon
Doug Beal
on Dec 31, 2009 at 6:19:07 am
locate someone in your area with an assimilate scratch system
have them do the shot repos for you
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Uli Plank
on Dec 31, 2009 at 10:01:52 am
If you don't need to keyframe the cropping/scaling, why not do it Clipfinder and use ProRes 4444?
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
