Red 2k workflow
COW Forums : RED Camera
Sean Davison
Red 2k workflow
on Oct 6, 2009 at 7:50:21 pm
Im working on a short film shot on RED at 4k 2.1 - laying back to HDCam SR.
Offline has been done using pro Res 422 HQ clips converted using RED Rushes to 1080x1920.
The plan is to convert the xml of the fnal sequence using clipfinder to point back to the r3d's for the color grade and send back to FCP for layback.
What is the best codec to render out to. Can I go 2k 444 dual link back to the SR - (is that just a question of linking the dual link output from the Kona to the HDCam SR and laying back?) How does the 2k frame size work if your going to HDcam SR (1920x1080) I know the Kona will convert on output but whats the point of rendering out to 2k if you're laying back to HD?
Help and advice appreciated
Noah Kadner
Re: Red 2k workflow
on Oct 6, 2009 at 8:13:26 pm
It's up to you- I'd suggest ProRes HQ at 1080p would be more than enough for most people's eye.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
Call Box Training
DSLR Cinematography Blog
Sean Davison
Re: Red 2k workflow
on Oct 6, 2009 at 8:30:00 pm
Thanks Noah - the Director wants the best possible - money no object but mastering on HDCam SR - Im confused as I keep hearing master on HDCam SR at 2k and Im not quite sure how you can do this as 2k is not HD?
If I rendered out Pro Res 444 and laid back to HDCam SR Dual link is this the best option? I presume Ill get black bands. Do they compensate for this when projecting?
Life on the Bleedin' Cutting Edge....
http://www.twotallmen.co.uk
David Battistella
Re: Red 2k workflow
on Oct 6, 2009 at 8:59:49 pm
You can output 2K to SR through the Kona.
if You shot 2:1 you would have to blow up slightly to eliminate the back bars but it also depends if you are doing a film out that is scope.
You for best quality, you would render out to one of the 2k presets in Color, send to FCP and then output the 2K timeline from FCP through the Kona to SR.
David
Peace
Check out my new web series.
http://www.ripperhockey.com
Doug Beal
Re: Red 2k workflow
on Oct 8, 2009 at 11:45:29 am
depending on the SR machine and the installed options
http://www.sony.co.uk/biz/view/ShowContent.action?logicalname=dms-SRW-5800L...
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
David Battistella
Re: Red 2k workflow
on Oct 6, 2009 at 8:18:33 pm
Sean,
Follow this exactly:
http://forums.creativecow.net/readpost/242/3158
Then what I do is I set the output in Color to 1920x1080 and render out a 4444 Apple Prores, sent eh sequence back to FCP and play it out the Kona dual link to HDCAM SR.
THis way all of the correct scaling is handled by Color instead of the Kona.
I would also remind you to add some level of sharpening to the RED footage in Color.
David
Peace
