Generating High Res Stills from RED
COW Forums : RED Camera
Hrabba Gunnarsdóttir
on Aug 1, 2009 at 10:46:50 am
I am trying to generate a high resolution still from 2K Red Material. All I seem to be able to generate is a 72dpi image from Red Cine as someone suggested. Is there any way to up the resolution and then how?
gary adcock
Re: Generating High Res Stills from RED
on Aug 1, 2009 at 12:57:33 pm
[Hrabba Gunnarsdóttir] "I am trying to generate a high resolution still from 2K Red Material."
Video Res is 72 DPI, and 2K material is going to be 2048x 1080 (1024)
fastest easiest way is to open the file in RedAlert and make 2K tiffs (use the make tiff button in the lower left side of the application window)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Check out
http://www.aja.com/kiprotour/
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
David Battistella
on Aug 2, 2009 at 6:01:14 pm
Gary is correct.
I also have used Clipfinder for this function. I like it because you can easily scroll to any point in a shot and then use the Apple-F key combo to create a still.
You can set the still shot size, tiff, jpg, etc in Clipfinder preferences.
I know that I go on about Clipfinder but it really has been a VERY handy program with many useful functions -- and it's free!
David
Peace
Check out my new web series.
http://www.ripperhockey.com
on Aug 3, 2009 at 12:40:53 pm
Thanks for the info... I understand that video is 72 dpi but I was somehow under the impression that resolution of red would somehow be higher :( but of course the frame is very big so that will compensate. I will definitely try both, Red alert and Clipfinder.
Best regards,
David Battistella
on Aug 4, 2009 at 3:29:39 am
The good news is that a 4K frame at 2:1 results in a 7x14 inch print size. That's a pretty nice contact print if you ask me and the prints I have pulled off of RED look stunning.
David
Peace
