fcs 3
COW Forums : RED Camera
Sean Davison
fcs 3
on Jul 29, 2009 at 5:14:10 pm
Installed FCS3 on a separate drive -
Exported test sequence from FCP - used clipfinder to change xml to target r3ds (via max proxy)
It doesn't seem to work with R3d's - no timeline playback and renders out as stills.
Any one got this working?
S
Russell Lasson
Re: fcs 3
on Jul 29, 2009 at 6:05:01 pm
So clip finder isn't rendering it? Did you try exporting XML v4 instead of v5?
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net
Sean Davison
Re: fcs 3
on Jul 29, 2009 at 6:34:10 pm
No,clipfinder seems fine
color won't play properly with the r3ds
I can alter metadata and zoom in so it's looking at the r3ds via y
the big proxy but it seems to appear as stillclips in the time line and renders out to all codecs as the same
this is all at 50i mind you
it wouldn't be the first time apple has bought out an update thAt doesn't work over here!
Sean Davison
Re: fcs 3
on Jul 29, 2009 at 6:34:38 pm
Ron Shaw
Re: fcs 3
on Aug 9, 2009 at 10:53:58 am
use the loop bug fixer on the Clipfinder website.
it fixed my r3ds
