Updating QT Reference when LUT changed in REDALERT?
COW Forums : RED Camera
Brandon Adams
on May 1, 2009 at 4:27:39 pm
For some reason the RED files I shot defaulted to REC709 instead of REDSPACE, so the Quicktime reference files play in REC709. If I delete the reference files, change the LUT in RED ALERT and then generate new reference files, they still display in REC709.
Anyone know what I'm doing wrong or have a solution?
Thanks.
-Brandon
Uli Plank
Re: Updating QT Reference when LUT changed in REDALERT?
on May 1, 2009 at 4:36:27 pm
FCP L&T doesn't recognize some parameters from REDAlert or Metadata (see whitepaper), but Color will give you all the options in the RED room.
Regards,
Uli
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Russell Lasson
on May 4, 2009 at 3:23:26 pm
Have you tried using REDRushes to make the new QT ref files?
-Russ
Russell Lasson
Universal Post
Ridgeline Digital Cinema Mastering
Salt Lake City, UT
David Battistella
on May 14, 2009 at 1:32:44 pm
open the r3d file in RED ALERT
make adjustments to the clip.
Select make quicktimes from the FILE MENU
The new QT files should now display the color space you have asked for.
David
Peace
