Green/Pink lines over image when editing
COW Forums : RED Camera
david jakubovic
on Apr 21, 2009 at 8:45:41 pm
Good Day,
I am cutting a video shot on Red. I imported the footage through FCP Log and Transfer, as ProRes HQ 422, and it all seems fine, until I start editing on a timeline. When I place footage on the timeline, it seems fine, it plays okay, but then it suddenly becomes green and pink and crazy looking and filled with lines.
I saw another post on this matter, and apparently others have had this problem. Someone's solution in the other post was to dump render files, another was to open another sequence and come back - all these work, but then the problem returns moments later.
Any ideas?
Uli Plank
Re: Green/Pink lines over image when editing
on Apr 21, 2009 at 8:49:24 pm
How fast is your machine?
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
david jakubovic
on Apr 21, 2009 at 8:37:00 pm
2 X 2.66 GHz dual core Intel
Memory: 4GB 667 MHz
About a year ago I edited Red footage that I converted to prores as well and it worked okay.
"We'll fix it in post"
Uli Plank
on Apr 22, 2009 at 5:57:49 am
And which graphics card? Sorry, I'm in the dark here.
I've read about the problem, but never seen it here in one year since we own the Red.
david jakubovic
on Apr 22, 2009 at 6:08:10 am
I don't know, but it appears the problem is due to a bizarre frame size, 2048/1152 which results from taking in 16:9 Red material through FCP's log and transfer. I resized it to 1920/1080 through Red Rushes even though I will go through three more lifetimes by the time it's done. But the scan line problem does not seem to happen this way. SO far. I haven't started cutting yet, but when a couple of cards have come in, I will try again.
Conclusion: 2:1 a much healthier option than 16:9.
If you have other conclusions I would love to hear them, because this is borderline insane.
David Battistella
on Apr 22, 2009 at 11:51:38 pm
Have you installed the latest QT codec from red.com?
Have you repaired permissions?
What are the monitor settings?
Are you seeing this on an external monitor?
Does it happen when you use a preset window layout?
David
Peace and Love :)
Read my Blog
http://blogs.creativecow.net/DavidBattistella
