After Effects and Color Space import
COW Forums : RED Camera
Dustin Bowser
on Apr 10, 2009 at 6:25:37 am
When installing the R3D support for CS4, there is a part at the very end of the install instructions that tell you how to edit the "Interpretation Rules" so that the imported R3D comes in using REC 709 color space rather than the super washed out and flat RED RAW. I was wondering, is there any way, instead of REC 709, to change that text file so that it uses any of the other color spaces? Like Red Cine?
jay jingles
Re: After Effects and Color Space import
on May 18, 2010 at 7:39:47 pm
I"ve got the same question as well.
When i import clips they are washed out, and adding the "interpretation rules.txt" modification does the same thing. If i manually go into the clip and select "default" under the "preset" dropdown it helps a bit, but still isn't what was shot on the day, nor what the quicktime proxies look like.
Any help is appreciated
thanks
