using red footage with Shake
COW Forums : RED Camera
Greg Pilon
on Mar 6, 2009 at 7:21:45 pm
I was just wondering if anyone has the best way to get 4k red footage into shake. I have started with FCP which rez's down to 2k. I want to fix a few shots in shake and also be able to use the Red 4k res. I am trying to figure out the best method for this. My current workflow not including shake is as followed:
1: converted red footage to prorez 422 for offline edit
2: Conform to footage back to relinking 4k files
3: Send to Color and Grade
4: Export for HD
I am just trying to figure where I can use Shake in this workflow and get full rez 4k stuff. I don't think it's possible with this. My thinking is I would have to use redalert somewhere in this workflow to stay at 4k and go into Shake, the import into FCP. I anyone has a better idea, please respond. Thanks Greg
Uli Plank
Re: using red footage with Shake
on Mar 6, 2009 at 9:50:47 pm
No, not with this workflow, it'll be 2K from Color. If you desperately need 4K (it's actually a resolution of about 3.2K), you need to transcode in REDAlert/REDrushes or Clipfinder. Expect long rendering times…
Regards,
Uli
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Greg Pilon
on Mar 8, 2009 at 1:55:04 am
Could I use Red Cine for this or is there a reason not to use Red Cine? I would like the resolution to zoom in on some clips. Thanks Greg
Uli Plank
on Mar 8, 2009 at 5:59:44 pm
I don't know. REDCine is very unreliable here, I use RA/RR or Clpfinder.
Regards,
Uli
