Shooting 25fps with 60hz lighting . . .
COW Forums : RED Camera
Chris Oben
on Feb 9, 2009 at 7:33:08 am
Is it possible to set the RED shutter angle to exactly 150 degrees with a system frequency of 25fps?
Shooting in North America - U.K. Client wants 25fps for PAL post / delivery . . .
Chris M. Oben
http://www.chrisoben.com
Noah Kadner
Re: Shooting 25fps with 60hz lighting . . .
on Feb 12, 2009 at 3:01:50 pm
I'd run tests but I'd imagine you'll get strobing.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Chris Oben
on Feb 12, 2009 at 7:28:51 pm
Hi Noah,
Thanks for your response . . . the whole idea of course is to avoid strobing altogether. The 150 degree shutter at 25 fps is exactly 1/60 which theoretically will eliminate 60hz flicker.
On set the 150 degree shutter did work - except that we were filming in a theatre with the projector set to 24fps! In the end the fluctuation of the projector was acceptable as our key lights were not flickering when we set to 1/60th shutter . . .
Chris Oben
Chris M. Oben
