Correct Output from Redcine to FCP?
COW Forums : RED Camera
Crystal Behrends
on Jan 12, 2009 at 11:06:13 pm
Hello,
I am trying to output the correct file from Redcine to FCP, but when I import the file I rendered out in Redcine, I get a message in Final Cut saying "The following media files are not optimized for Final Cut Pro". I am going from 4K to 1080 and here are the settings I am using:
PROJECT - RedSpace (also tried CameraRGB)
SHOT - Framing: Fit to Width
OUTPUT - Quicktime, AppleProRes422, HD 1080, Full
What am I doing wrong? Any help will be greatly appreciated! Thanks in advance.
Noah Kadner
Re: Correct Output from Redcine to FCP?
on Jan 13, 2009 at 1:27:39 am
That's not necessarily a dealbreaker. FCP reports that when it doesn't like a particular combination of codec, resolution and frame rate but that wouldn't prevent you from cutting.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Crystal Behrends
on Jan 13, 2009 at 2:31:48 am
Well, FCP lets me import the files after they give the warning, but when I try to export the sequence to Color, the program starts to act up. Once I delete the clips exported from Redcine, Color works fine again.
Is there a correct setting to use when exporting from Redcine?
Asher Castillo
on Jan 16, 2009 at 3:05:59 am
Using Color in a final pass could you use the proxy files to edit with and skip Redcine?
Uli Plank
on Jan 16, 2009 at 7:02:53 am
You can skip RedCine, but don't use proxies, use the native ingest by L&T as described in Apple's whitepaper. Proxies are causing problems in Color if the original R3D files are spanned (which they are in most cases).
Regards,
Uli
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
