Red 4k workflow
COW Forums : RED Camera
luke hardiman
Red 4k workflow
on Jul 11, 2008 at 12:33:33 am
I am planning a shoot, which will finally be mastered to HD, but I want to shoot and work in 4K, and use the extra resolution to put in zooms and pans in post.
From the research I've done though, it seems that the work flow for using 4k files in After Effects involves going through Scratch on a PC.
Is that correct, or is there a work flow for the Mac that will work.
Dylan Reeve
Re: Red 4k workflow
on Jul 11, 2008 at 3:08:23 am
After Effects supports DPX I believe, so there's no reason you couldn't use DPX sequences in After Effects on the Mac. Use FCP to edit with proxies, then use Crimson to generate DPX sequences from your edit.
I'm not sure I'd try. I'm also not sure there is any real benefit to working at 4K that long when finishing for HD.
Ben Holmes
Re: Red 4k workflow
on Jul 15, 2008 at 12:08:05 am
You can absolutely output to dpx and pan and scan in after effects - you just better have a lot of storage, and fast drives.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
luke Hardiman
Re: Red 4k workflow
on Jul 15, 2008 at 2:15:37 am
Thanks for the advice guys
© 2018 All Rights Reserved
