How to adjust event length when changing properties>playback rate?
COW Forums : VEGAS Pro
Carlos Silva
on May 31, 2016 at 11:23:25 pm
I would appreciate help:
When I select event properties and change playback speed to 2.0, the event isn't changing the length. I mean, Event length in normal playback speed has 10 minutes in the timeline. After increase properties>playback rate, event is still having 10 minutes. I was expecting event would change length to 5 minutes.
Many Thanks!
Carlos_
Wayne Waag
Re: How to adjust event length when changing properties>playback rate?
on Jun 1, 2016 at 3:22:24 am
If you want to change the playback rate and adjust event length at the same time, simply Ctrl-drag the end of your event to the left. E.g. if you ctrl-drag a 1 min event to 30 sec, the playback rate will be 2.0.
wwaag
