Is there a way to render m2t video with ac3 audio?
COW Forums : VEGAS Pro
Gama Strode
on May 25, 2016 at 11:46:14 pm
Hello,
i am trying to broadcast advertisements on a Telvue Adcaster,
and it only accepts certain formats. i have a few that work, but i can't seem to render any in vegas that work.
i need the following format: this is from Mediainfo
General
Format : MPEG-TS
File size : 53.4 MiB
Duration : 29s 863ms
Overall bit rate mode : Constant
Overall bit rate : 15.0 Mbps
Video
Format : MPEG Video
Commercial name : HDV 720p
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : 2
Duration : 29s 396ms
Bit rate : 14.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 (60000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.253
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 49.3 MiB (92%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 29s 344ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Stream size : 688 KiB (1%)
Language : English
Is anyone familiar with achieving this format? Is there a way to perhaps transcode the audio and leave the video in HDV 720p ?
I really need help on this! been at it for 2 days
Wayne Waag
Re: Is there a way to render m2t video with ac3 audio?
on May 26, 2016 at 4:02:28 am
You're on the right track. First, do a normal HDV render. Second, do an AC-3 render. And finally, do a remux in which you replace the audio track from the HDV render with the audio track from the AC-3 render. You can use software such as TMPGEnc's Smart Renderer for remuxing. Or you can probably use FFMPEG. It's a command line program and a bit more difficult to use, but its freeware. I use FFMPEG all the time for remuxing AAC audio files with MP4 files. You could also search the tools section in Videohelp.com for other software that supports remuxing.
wwaag
Gama Strode
on May 27, 2016 at 2:28:52 pm
Thanks alot, I am using Tsumuxer right now, trying to figure it out.
Can't afford the one you mentioned right now. Will repost with results
Wayne Waag
on May 27, 2016 at 2:53:34 pm
Tsmuxer does not work importing m2t files. Tried it with both v1.1 and v2.6. Moreover, there is no export option for m2t files, only .ts or .m2ts files. Did you search the tools section on Videohelp? I'll try FFMPEG and if that's successful, I'll post the necessary command line.
wwaag
Wayne Waag
on May 27, 2016 at 3:59:40 pm
One thing you can do with TSmuxer is first do your render from Vegas so that the output is elementary streams (m2v and mpa). The m2v file and ac3 files can then be loaded into TSmuxer and you can create a m2ts file directly.
wwaag
Gama Strode
on May 27, 2016 at 6:21:14 pm
I am now using Telestream Episode 7.1
This looks like just the program I am looking for.
I have rendered the file as M2T, With AC3 Audio.
However, look at this:
Overall bit rate : 15.2 Mbps
I was specifically told to have a bitRate not exceeding 15.
And I cannot get this program to render below 15.2.
And now i cannot find the option to change Bandwidth, as stated in the manual.
Always some kind of road block. Almost there!! Man this is day 3 trying to figure this out !!
Wayne Waag
on May 27, 2016 at 11:30:31 pm
Just lower your bit rate when rendering from within Vegas.
wwaag
Gama Strode
on May 27, 2016 at 4:54:30 pm
Okay I will try that (m2v)..
Yes, I looked at VideoHelp conversion forum, downloaded all the tools listed, & have not been able to get any to do what I need.
You are correct about Tsumixer not importing M2t.
I have also tried using Super, using "Copy Stream" (which says will not change the video), and Audio Output: AC3.
But it just renders to an .MPG file. I see no options for M2ts/M2t containers.
I understand ffmpeg is hard to install. I will try it again, as I could not get it to work before
Gama Strode
on May 27, 2016 at 5:10:48 pm
Okay, so using Super, i successfully got AC3 audio on an M2Ts file. I was wrong, there is both a .ts and .M2Ts container.
However, I don't think the Telvue Adcaster accepts M2Ts.
And of course, the adcaster is currently down, so i cannot test it.
Frustrating!
