Capture window goes black during capture with Win10
COW Forums : VEGAS Pro
John Romein
on May 11, 2016 at 10:15:45 pm
Capturing DV shows black window in Win10.
When I first installed Win10 late last year Vegas 13 worked fine. Then just after Christmas the DV capture window showed a problem. If the capture button has not been pushed, the capture windows shows the inputting image. The second the capture button is pushed, the capture image goes black until the stop is selected...then the window shows the capturing image.
I spoke to Microsoft as I suspected a Win10 update caused the problem. We backed out the update that was done in late Dec 2015 (and flagged it not to apply again)and the capture window worked fine again. In February the problem re-appeared!!
Recently I was talking to someone and found out he was having the same issue.
Does anyone else have this issue and has anyone found a solution?
