Clips in Sony Vegas will not fade with each other?
COW Forums : VEGAS Pro
Anoop Singh
on May 6, 2016 at 1:44:29 pm
Please forgive me as I am a slight newbie, but I am not able to cross fade selected clips together.
For example, I can't seem to make the ending of a clip fade with the beginning of another clip that are on the same timeline. I don't know why but this never ever happened to me before and I have no idea why I am not able to do this.
Could someone please kindly help me?
Thankyou,
Solid-Snoop.
Truth is Higher, but Higher is Truthful Living (Guru Nanak Dev Ji)
Mike Kujbida
Re: Clips in Sony Vegas will not fade with each other?
on May 6, 2016 at 2:30:12 pm
Under the Options menu, select Automatic Crossfade.
The shortcut is Ctrl+Shift+x
It's also a toolbar icon.
Andrew Lenczycki
on May 6, 2016 at 7:15:22 pm
Are you overlapping your two video events? The amount of overlap is the amount of time the two will be transitioning from Event 1 to Event 2.
Andrew Lenczycki
