Moving a group of clips all together
COW Forums : VEGAS Pro
Dáithí Cinnsealach
on Apr 26, 2016 at 2:44:23 pm
So when I delete a clip I have to move the clips to the right manualy one by one, which takes a long time. Is there any way to highlight those clips and move them to the left?
Aaron Star
Re: Moving a group of clips all together
on Apr 26, 2016 at 7:09:57 pm
I would read up on Ripple Edit in the help file and see if that is what you need.
Wayne Waag
on Apr 26, 2016 at 7:50:02 pm
So when I delete a clip I have to move the clips to the right manually one by one,
You can also go the first clip after the one deleted, right-click and then click on "Select Events to End" and then drag them all at once.
However, if you're doing simple cuts editing with not much else on your timeline, then use of ripple edit as Aaron suggested is even easier and faster.
wwaag
Graham Bernard
on May 7, 2016 at 2:58:26 am
I use Ripple Edit all the time for this. BUT, it is a very powerful tool indeed. Do make sure you switch it off after use.
* Grazie
