Vegas Pro has stopped working
COW Forums : VEGAS Pro
art willig
on Apr 26, 2016 at 4:29:50 am
Suddenly getting these errors in Vegas Pro 10.
Have no idea why this would suddenly happen.
However, after closing, it says that the SYSTEM has recovered from a serious error so I'm thinking perhaps Windows XP Pro is messed.
What do you think?
Problem Description
Application Name: Vegas Pro
Application Version: Version 10.0c (Build 469)
Problem: Unmanaged Exception (0xc000001d)
Fault Module: C:\WINDOWS\system32\SHELL32.dll
Fault Address: 0x7CD0DF3C
Fault Offset: 0x0034DF3C
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
Process Version: Version 10.0c (Build 469)
Process Description: Vegas Pro
Process Image Date: 2011-01-03 (Mon Jan 03) 17:02:04
Problem Description
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\WINDOWS\system32\ntdll.dll
Fault Address: 0x7C9113A0
Fault Offset: 0x000113A0
Problem Description
Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\FileIO Plug-Ins\compoundplug\mc_dec_avc.dll
Fault Address: 0x1DC1AE7D
Fault Offset: 0x001EAE7D
Mike Kujbida
Re: Vegas Pro has stopped working
on Apr 26, 2016 at 10:00:14 am
You're running 10.c and 10.e is the latest version for Pro 10 so I recommend upgrading to it first and see if your problems go away.
http://www.sonycreativesoftware.com/download/updates/vegasfamily
art willig
on Apr 26, 2016 at 7:59:09 pm
Updated to 10e...still the same problem.
Getting these OS errors now...
LOCALS~1\Temp\WER4690.dir00\Mini042616-02.dmp
LOCALS~1\Temp\WER4690.dir00\sysdata.xml
Offhand, it looks like it can't open the hundreds of clips on the timeline. It stops and throws the vegas has stop working error.
Aaron Star
on Apr 26, 2016 at 8:13:50 pm
You know Win10 with Vegas 13 B473 is probably more stable and feature rich.
With some huge number of files, you may be hitting the memory ceiling for 32-bit Vegas. Upgrading to Win10-64 and Vegas 13 may solve this if this is the issue. Not sure what type a project would require a huge number of source files to hit that ceiling. If you are trying to do timelapse, use image sequence import vs dropping on the timeline.
Here are a few things to try with such an old system:
Clean it out top to bottom, and reseat cards and memory
Run CCleaner - Reboot
Run Malware Bytes and check for bugs.
Check HDD for surface errors or failures.
Then test RAM for failing blocks with Memtest86+ outside of windows, and run a complete set of tests. Any errors found at all mean you need new ram in that slot.
Upgrade the machine to something modern
art willig
on Apr 27, 2016 at 9:20:40 pm
I first ran memtest86+ which threw millions of errors before I shut it off. Then I opened the box only to find one of the memory stick has popped out. Everything works again.
I've hundreds of short clips on the timeline that I copy to another timeline. I was wondering if I should put these in media folders or does it really matter?
