how can i send a project?
COW Forums : VEGAS Pro
Mehmet Ali Avci
on Apr 6, 2016 at 8:53:36 am
I have to send a vegas project to my friend. He has to render it for me. since my computer cant render for some odd reason...pls help me.
Wayne Waag
Re: how can i send a project?
on Apr 6, 2016 at 6:23:12 pm
You should really try to figure out why you can't render from your own computer. For help, you would need to provide details about your source media, project settings, and render settings, as well as information about your PC.
If you must send your project to someone else, you must include all of your media files as well as your project file. Since your media files are probably located in different folders, the easiest thing is to create a new folder and then do a project "save as" to that folder, making sure that the "Copy media with project" box is ticked. In this way all of your source media will be copied to the same folder, making it much easier for someone else to open your project and do a render.
wwaag
John Rofrano
on Apr 7, 2016 at 1:45:10 pm
[Wayne Waag] "...the easiest thing is to create a new folder and then do a project "save as" to that folder, making sure that the "Copy media with project" box is ticked. In this way all of your source media will be copied to the same folder, making it much easier for someone else to open your project and do a render."
+1
...and depending on the size of your media, you may need to buy a portable drive to send to your friend because your project will probably be too big to send via any other means.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
