Can't preview CC in the preview window - only see first one and the others don't show up
COW Forums : VEGAS Pro
Amanda Duffield
on Apr 4, 2016 at 1:43:41 pm
Vegas Pro 13
I make captions in DVD architect Pro and then import them into Sony Vegas 13. (Mostly because I know all the quick keys etc for Architect and I'm much faster doing it there).
Once they've been brought in, I want to have one last look to confirm timing/spelling etc is ok.
When I play the footage, I see the first caption and then none of the others 'refresh'.
The only workaround I could figure out was, as I'm watching, I press the right arrow every time the next CC is due, and it shows up but there are hundreds of captions, I'm not doing this continually.
So, I'm basically scrolling manually through the CC's to check them, they don't show up on their own.
Is there any way to confirm all is good before rendering?
Also, I'm pretty sure I've asked this one before, but can I then burn-in the captions as open captions? I know Vegasaurus does it, but the whole 'convert to text' thing is problematic, it's never a quick changeover, there's always lots of extra changes to make - but that could be me :)
Thanks.
John Rofrano
Re: Can't preview CC in the preview window - only see first one and the others don't show up
on Apr 4, 2016 at 11:38:37 pm
Make sure that you have the latest build for Vegas Pro 13.0. Earlier builds had a bug where CC would not update.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Amanda Duffield
on Apr 5, 2016 at 1:58:26 pm
Thanks.
Is that just a matter of going to web and upgrading?
Mike Kujbida
on Apr 5, 2016 at 2:08:44 pm
Yes it is. Just go to http://www.sonycreativesoftware.com/download/updates/vegaspro and grab the latest version.
John Rofrano
on Apr 5, 2016 at 8:15:40 pm
You can also check for updates from the Help menu (if I remember correctly). Just install the latest version over what you have and it will perform an upgrade.
~jr
