Render 4K with Transparency with VP12?
COW Forums : VEGAS Pro
Tim Neighbors
on Mar 31, 2016 at 10:34:45 pm
is there any way to render a project with Alpha (transparency) in UHD resolution with Vegas Pro 12?
Will I be able to if I upgrade to VP13?
For HD I typically do this with QT -animation or PNG codec, but I don't see an option to do 4K and when I try to do it with a custom frame size set to UHD resolution, I get a 2000x2000px file.
John Rofrano
Re: Render 4K with Transparency with VP12?
on Apr 1, 2016 at 2:46:34 pm
[Tim Neighbors] "Will I be able to if I upgrade to VP13?"
Yes! Vegas Pro 13.0 supports 4K QuickTime renders using the Animation or PNG codecs, both of which carry an Alpha channel.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
