Selection Duration
COW Forums : VEGAS Pro
Nah Roots
Selection Duration
on Mar 28, 2016 at 10:53:15 pm
I simply cannot figure out how to bring the "selection duration" field back into the lower right hand corner of Vegas. As you can see in the attached image, the "selection start" and "selection end" fields are visible, the the third field is missing. Anybody know what setting in Vegas needs adjusting so I can see this field again?
9927_eventduration.jpg.zip
Thank you
Graham Bernard
Re: Selection Duration
on Mar 29, 2016 at 3:20:12 am
If you wish to post a JPEG you don't need to wrap it in a ZIP.
* Grazie
Jorma Nippala
on Mar 29, 2016 at 8:47:41 am
Your track header area is probably too wide. Drag left between the track list and timeline (track view) to make more space to the latter. The edit boxes area below the timeline responds earlier than the previous versions, if you widen the track list.
Nah Roots
on Mar 30, 2016 at 5:58:36 pm
Thank you!
I was so convinced there was a setting for it, I never even considered adjusting the track header area.
