Preview Lag
COW Forums : VEGAS Pro
Shyre Thakkar
Preview Lag
on Mar 23, 2016 at 11:45:07 pm
So i just got sony vegas 13 pro on my computer and threw some footage to edit in and it was going all good until i reached around the 20 minute mark. then the preview window started lagging to like 3 frames a second. my pc specs are
Intel i-7 6700K CPU
GeForce GTX 960
250 GB SSD
I thought this would be enough to run Vegas but i am still running into this lag problem. I looked up some solutions but none have worked yet. Any help would be appreciated. Thanks
Steve Rhoden
Re: Preview Lag
on Mar 24, 2016 at 1:17:48 am
Lagging during preview playback of certain video formats is normal at times.
I do not categorize that as a problem!
The most important thing to keep in mind, is that as long as its not your
final renders that are lagging, then all is well.
Furthermore you need a lot more than just 8GB of RAM.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
Shyre Thakkar
Re: Preview Lag
on Mar 24, 2016 at 3:47:58 am
its getting pretty hard to edit effectively at 2 frames a second though. i thought for Sony Vegas 13 8GB is the recommended amount?
john bolton
Re: Preview Lag
on Mar 24, 2016 at 8:27:23 am
What have you set the Preview quality at? Best or Preview Auto
Scott Francis
Re: Preview Lag
on Mar 24, 2016 at 7:37:17 pm
make sure you have "disable resample" clicked under the video event properties.
Also, are you using more than one video track? Are you using composite envelopes? If you have your opacity or a composite level below 100% and a video track is below it, Vegas is trying to mix the two.
Same issue if you have a clip above and and the composite level envelope is not at 0% it will try to mix the two. This REALLY slows down a video preview.
Trust me, I edit my multicam projects with envelopes and sometimes I am hunting for that one fade level keyframe that is not at 100% or 0%.
Also, if you are using FX it can also really affect the preview quality.
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
© 2018 All Rights Reserved
