track motion in sony vegs pro 13 is not popping up
COW Forums : VEGAS Pro
sai surya
on Mar 13, 2016 at 11:38:28 am
I installed sony vegas pro 13 recently,the track motion was worked fine for some time later when I click the track motion button it is not popping up, do I need to enable any other button in order to enable tack motion.
Please guide me.
Thanks in advance.
Paul Berk
Re: track motion in sony vegs pro 13 is not popping up
on Mar 13, 2016 at 6:20:25 pm
Sounds like you lost the Track Motion window somewhere. Check all your floating windows.
sai surya
on Mar 15, 2016 at 8:32:24 am
I checked all the floating windows even I restarted my laptop but nothing worked.
I created a new project and clicked the track motion button but no luck.
Can you guess what the problem can be?
Thanks.
Edward Troxel
on Mar 15, 2016 at 5:08:41 pm
My guess is that it's hidden under the "start" bar. Either change the resolution temporarily and locate it and move it back or hide the start bar.
Edward Troxel
Paul Berk
on Mar 15, 2016 at 5:16:41 pm
Save your current windows layout -- then change it to the default layout. Is track motion still missing using the default windows layout.
view/windows layouts/default layout
