Changing speed without the obvious fade result
COW Forums : VEGAS Pro
derek hammer
on Mar 10, 2016 at 4:52:18 pm
Hi there,
I sped up some footage but it always looks obvious because of the movement. It's hard to describe but just the movement between frames. For example, it seems that when it goes from frame 1 to frame 2, there's still a trace of frame 1 there. Any ideas? Is it about disabling resample?
I appreciate it!
Wayne Waag
Re: Changing speed without the obvious fade result
on Mar 10, 2016 at 5:19:46 pm
Probably. Disable resample for those events and see if it's better.
wwaag
John Rofrano
on Mar 17, 2016 at 11:25:16 am
It sounds like "fading between frames" is really Frame Blending that happens because of Resampling. If you Disable Resample this should stop.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
