Pitch shifting doesn't work in Sony Vegas 13
COW Forums : VEGAS Pro
Jeroen van Weperen
on Mar 9, 2016 at 3:34:11 pm
Title pretty much sums it all up. I press the +/- key with the audio selected, but nothing happens. I've tried holding the ctrl, alt, shift and tab keys while pressing + and -, but nothing works.
Does anyone know how I can fix this?
Paul Berk
Re: Pitch shifting doesn't work in Sony Vegas 13
on Mar 9, 2016 at 5:44:27 pm
Works for me on V13 Pro Build 453. This is one feature in Vegas I've never used.
Paul Berk
on Mar 9, 2016 at 5:48:22 pm
Ok. I do see a problem. Initially you can change the pitch, but once changed and the focus goes elsewhere, coming back to the event it no longer responds to + or - or = .. If you add the same event back as a "take" it responds again to the new active take. I have no idea if this behavior is normal.
Jeroen van Weperen
on Mar 13, 2016 at 11:30:30 am
Ah! I found the problem!I had set the pitch change to 'Lock to stretch', cause I liked the way it changed the pitch when I sped up/slowed down a clip. This however, prevented me from changing the pitch manually, without slowing down/speeding up the clip itself. Thanks for your reply anyways!
