Video: Stream attributes could not be determined
COW Forums : VEGAS Pro
Tom Edwards
on Mar 6, 2016 at 6:14:31 pm
Hi.
I have been experimenting with a new workflow to include DaVinci Resolve.
I'm shooting in RAW and then utilizing DaVinci to output/deliver the media, then I'd use SVP13 as my NLE. The final video from DaVinci plays fine in my VLC player.
However, when I add the media to SVP 13 it shows up in the timeline on an audio track. And when I click on the video in the SVP13 Explorer tab, it shows "Video: tream attributes could not be determined"
The two files I'm working with are described by MediaInfo below:
Anyone have pointers? Are there some codecs that need to be installed in SVP 13?
Complete name : C:\Users\tome\Videos\workbench\RAW\Uncompressed YUV 422 10-bit.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 5.61 GiB
Duration : 45s 379ms
Overall bit rate : 1 062 Mbps
Encoded date : UTC 2016-03-06 18:01:19
Tagged date : UTC 2016-03-06 18:03:30
Writing library : Apple QuickTime
Video
Format : YUV
Codec ID : v210
Codec ID/Hint : AJA Video Systems Xena
Bit rate mode : Constant
Bit rate : 1 061 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 10 bits
Compression mode : Lossless
Bits/(Pixel*Frame) : 21.333
Stream size : 5.60 GiB (100%)
Language : English
General
Complete name : C:\Users\tome\Videos\workbench\RAW\DNxHD 1080p 444_.mov
Format : QuickTime
File size : 1.87 GiB
Overall bit rate : 354 Mbps
Encoded date : UTC 2016-03-06 17:53:54
Tagged date : UTC 2016-03-06 17:54:58
Video
Format : VC-3
Codec ID : AVdn
Codec ID/Info : Avid
Codec ID/Hint : DNxHD
Bit rate : 352 Mbps
Color space : YUV
Scan type : Progressive
Bits/(Pixel*Frame) : 7.080
Stream size : 1.86 GiB (100%)
Language : English
John Rofrano
Re: Video: Stream attributes could not be determined
on Mar 6, 2016 at 6:24:30 pm
I'm guessing that Vegas Pro doesn't support the raw output from the AJA Xena in a QuickTime wrapper. I'm not sure why it can't open Avid DNxHD files though. They should work.
My advice, and you're not going to like this... if you want to work with 10-bit 4:2:2 QuickTime files... buy a Mac. It would be so much easier. Seriously, Vegas Pro is the wrong NLE for this kind of workflow.
Your only option is convert these files to something Vegas Pro can edit. Perhaps convert them to CineForm AVI coming out of DaVinci?
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Tom Edwards
on Mar 6, 2016 at 6:54:55 pm
No Macs in my house - not gonna happen. I'm a Linux and Windows guy... Windows 10 and a lot of beef for my NLE workstation
Anyway, I did output to AVI Uncompressed YUV 422 10-bit and it did come right in to SVP 13 - you were spot on!
As to the other formats that Resolve outputs, do you know if any of these formats work?
Cineon
DPX
EXR
easyDCP
MXF OP-Atom
MXF OP1A
John Rofrano
on Mar 6, 2016 at 7:05:38 pm
The only other format that Vegas Pro accepts from that list is MXF but I believe it's looking for either MPEG2 or AVC/H.264 in an MXF container.
AVI is the native format of Windows so I would just stick with that. If Resolve gives you codec options, you could download the free GoPro Studio to get the CineForm codec. That will be much smaller than uncompressed.
~jr
