MKV in Sony Vegas
COW Forums : VEGAS Pro
Mark van der Berg
MKV in Sony Vegas
on Mar 3, 2016 at 10:05:01 am
Okay, I cannot get an MKV file loaded into Sony Vegas. I have tried converting it with VLC, ffmpeg, avidemux, but I keep getting error messages. Any help?
Graham Bernard
Re: MKV in Sony Vegas
on Mar 3, 2016 at 1:13:12 pm
Try HandBrake.
* Grazie
Wayne Waag
on Mar 3, 2016 at 4:42:54 pm
Your MKV files need to be re-muxed into something that Vegas will import. You could use Handbrake, but that will result in a re-render and some quality loss. Plus it will take a relatively long time. Try TSmuxer (freeware) which will produce a .ts or .m2ts which Vegas should read without issue. You could also re-mux to MP4. All this assumes that the actual codec inside the container is h264 (AVC). Re-muxing will also be very quick since it mostly involves "copying".
wwaag
