MP4's from Vegas won't work in iTunes
COW Forums : VEGAS Pro
Scott Francis
on Feb 19, 2016 at 2:53:20 pm
Hey All,
Have a client who uses iTunes for all their video. When I render out videos in Vegas to MP4 (using main concept), iTunes will not load them. If I run them through Handbrake, they work fine.
Does Vegas not use h.264 or what may be the issue here.
My biggest client, so would love to avoid another step in post.
Thanks in advance!
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
Steve Rhoden
Re: MP4's from Vegas won't work in iTunes
on Feb 19, 2016 at 3:02:23 pm
Use Sony AVC instead and you will have no issues at all.
I have always prefer it over Mainconcept's.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Scott Francis
on Feb 19, 2016 at 3:24:43 pm
Sony doesn't have some of the adjustments that Mainconcept does like 2 pass that I use and such.
Also the WHY does it not work is kinda what I am looking for.
Steve Rhoden
on Feb 19, 2016 at 4:03:46 pm
The WHY you are looking for is an iTunes issue.
The thing to do then is to find out what are their exact and detailed video
requirements for uploading!
Wayne Waag
on Feb 19, 2016 at 5:01:06 pm
If Handbrake works, why not use it? It's a much better encoder than MC, especially at low bit rates. You can do 2 pass encoding as well. There is even a script that permits one-click rendering from Vegas. http://www.vegasvideo.de/vegas-2-handbrake-en
wwaag
Steve Rhoden
on Feb 19, 2016 at 5:12:33 pm
Exactly Wayne! I also pointed out that exact link to the Handbrake script
to you in a previous thread Scott.
Scott Francis
on Feb 20, 2016 at 12:56:49 am
Because one doesn't do the editing in Handbrake that you do in Vegas guys!!
Not every video is straight from raw footage to MP4 finished edit.
Surprised you guys didn't realize that!
These were VHS transfers with color correction, noise reduction and pan/crop adjustments.
I will look into the scripting provided.
Thanks guys!
Wayne Waag
on Feb 20, 2016 at 1:42:18 am
I think its YOU that has a very basic misunderstanding. You DO the editing in Vegas as always, but RENDER in Handbrake rather than using either Mainconcept or Sony AVC--simple as that.
wwaag
Steve Rhoden
on Feb 20, 2016 at 2:27:21 am
No, You are the one who is failing to realize what we are telling you!
You do the editing in Vegas and render out as you normally would, but
this time its via Handbrake. That's what the script does that we are
pointing out to you.
Scott Francis
on Feb 20, 2016 at 2:39:03 am
Yes, I am seeing that now. You know, not everyone is up on scripting and making it so one program works with another in this manner. I see what you are saying now, but that doesn't mean that it is always clear at first.
Appreciate the input.
John Rofrano
on Feb 20, 2016 at 6:28:23 pm
[Scott Francis] "Have a client who uses iTunes for all their video. When I render out videos in Vegas to MP4 (using main concept), iTunes will not load them."
What version of Vegas Pro are you using?
What render template are you using?
Have you tried the Apple iPad/iPhone 4 720p30 Video template? That plays back fine in iTunes on my Mac.
Is your client using a PC or a Mac?
What version of iTunes?
What version of Mac OS X? or PC Windows?
If they are using a really old version of iTunes on Windows XP that's a lot different problem than if they are using iTunes 12.3 on Mac OS X 10.11.3.
[Scott Francis] "Does Vegas not use h.264 or what may be the issue here."
I'm guessing the issue is the render template that you are using and not the MainConcept AVC encoder itself. You also didn't say what version of Vegas Pro you are using. Older versions didn't have the Apple HD templates.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Scott Francis
on Feb 21, 2016 at 2:38:16 am
Latest version of SVP13
They are 4:3 SD VHS transfers to MP4
The client is all Mac and I have no clue about any of there specs.
I used the 4:3 template in the Main concept for this specific set of renders.
He has also had issues with using the Apple settings, and I know that they use 30p and 24p on some of there templates.
I don't use iTunes for numerous reasons, however I do use Quicktime and Quicktime Pro on all my PC's and the videos play fine on that
Hope that helps
John Rofrano
on Feb 21, 2016 at 3:34:09 am
[Scott Francis] "The client is all Mac and I have no clue about any of there specs."
Then you need to ask them because it's extremely important in order for you to figure this out.
I'm telling you that MainConcept AVC rendered from Vegas Pro 13.0 using the "Apple ..." templates play perfectly fine on Mac OS X 10.11 El Capitan with iTunes 12. So you need to find out what's wrong with your client's Mac setup. How old is it?
[Scott Francis] "I used the 4:3 template in the Main concept for this specific set of renders."
Did you try the Apple iPod 640x480 Video template? That should work fine. I'm playing these rendered videos on my Mac with iTunes right now and they work.
~jr
