Markers in WAV file disappear in Trimmer
COW Forums : VEGAS Pro
Omer Aydin
on Feb 17, 2016 at 12:36:54 pm
I have noticed that markers I previously dropped in trimmer disappear when I reload a WAV file.
This issue happens in both Vegas 9 and 13, and only while working with `some` WAV files.
I tested it on 2 different WAV files, one rejects the markers while the other keeps them.
Any suggestions ?
Thanks in advance,
John Rofrano
Re: Markers in WAV file disappear in Trimmer
on Feb 17, 2016 at 1:00:37 pm
[Omer Aydin] "I tested it on 2 different WAV files, one rejects the markers while the other keeps them."
It sounds like you need to determine what's different about the two WAV files. Is one of them read-only? Use a utility like MediaInfo to compare the contents. Are they the same? As you have seen, the markers should be saved with the WAV file. Check the read-only bit first. If they came from read-only media like a CD, they may have retained their read-only status.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Omer Aydin
on Feb 17, 2016 at 1:24:45 pm
Thanks for the quick response John, I checked them with MediaInfo and the only difference was one of the files had a meta data saying it was rendered in ProTools.
I opened it in SoundForge, made a null change and saved over the original. Now Vegas is able to write marker data into that file.
I guess Protools writes some info in the area that Sony uses for marker data so Sony avoids overwriting it.
John Rofrano
on Feb 17, 2016 at 3:15:56 pm
Wow that is strange. I'm glad you figure out a workaround.
~jr
