Sony Vegas Pro 13 rendering freeze!
COW Forums : VEGAS Pro
Raffaello Ciotta
on Feb 13, 2016 at 6:12:56 pm
hi! i have an incredible problem. I am trying to render a video, but all the times, when the rendering is at 1139 frames, the video stop to be played. The time goes on, but the video don't be renderized.
I've tried to unistall and reinstall the program but nothing happened!
I am trying to fix this problem from 2 hours! Please help me! D:
P.S. sorry for bad english, i am italian :c
Graham Bernard
Re: Sony Vegas Pro 13 rendering freeze!
on Feb 13, 2016 at 8:41:03 pm
Are you using a MainConcept template?
* Grazie
Steve Rhoden
on Feb 13, 2016 at 9:23:52 pm
Or something is wrong with that particular piece of video located at
that point!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Graham Bernard
on Feb 13, 2016 at 9:43:42 pm
Or...both.
* Grazie
John Rofrano
on Feb 14, 2016 at 12:21:47 am
Make a timeline selection around the area that you can't get past and try and render just that section. If it doesn't work, there is probably some corrupt media that is causing the render to fail. Start muting video tracks and re-render that section until the render works. When it does, the media on the last track you turned muted contains the bad media.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Graham Bernard
on Feb 14, 2016 at 7:52:59 am
[John Rofrano] "Make a timeline selection around the area that you can't get past and try and render just that section."
Yes. I use the "Render to New Track" Tool, using this approach we get a clear "map" of just what and where we have rendered and we can see how we are closing in on the problem media.
Here's that "map" of Render To New Tracks, giving me a simple forensic way to determine where an issue is:
* Grazie
