Vegas Pro 13.0 Weird problem when adding text/Video Effects
COW Forums : VEGAS Pro
Ricardo Caro
on Feb 8, 2016 at 4:13:59 pm
Need help!! :)
Generated Media Box is not fully showed, as you can see in this clip:
https://gyazo.com/bf6e744d457b2620d7842b439d18bbf2
same thing happens with video FXs
Example: https://gyazo.com/d0924fd9e566f6437ffbbb60f3a28729
Graham Bernard
Re: Vegas Pro 13.0 Weird problem when adding text/Video Effects
on Feb 8, 2016 at 4:59:18 pm
Yeah, this rings a bell. What Build of VP13 is that?
* Grazie
Ricardo Caro
on Feb 9, 2016 at 12:42:35 am
Build 453
Steve Rhoden
on Feb 9, 2016 at 2:14:29 am
Have you already tried re-installing and resetting Vegas?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Mike Kujbida
on Feb 9, 2016 at 3:24:40 am
If you adjusted your monitor font size larger than 100%, set back to normal size.
John Rofrano
on Feb 9, 2016 at 4:39:30 am
[Mike Kujbida] "If you adjusted your monitor font size larger than 100%, set back to normal size."
+1
Yea, setting your monitor DPI to anything other than 100% will mess up applications. This is a really poorly implemented feature in Windows. Always keep your display size at 100%.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Colin Moxey
on Feb 10, 2016 at 12:58:19 pm
Thanks Ricardo for bringing up this subject. I have the same thing happening, but only when I use MEDIA GENERATORS/Credit Roll.
Thank you Mike and John for your suggestions regarding the monitor DPI setting at 100%.
I'm set at this and still have the problem.
I blame myself for setting up 2 monitors. I cannot fault Sony Vegas as this happened when I was using version Pro 12 and now with Pro 13 -453
Ricardo, did the suggested fix work ok for you?
thanks guys
Ricardo Caro
on Feb 11, 2016 at 6:29:32 pm
Problem hasn't been solved :/ tried eveything
Ricardo Caro
on Feb 11, 2016 at 6:28:44 pm
It always been at 100% :(
Graham Bernard
on Feb 11, 2016 at 8:57:53 pm
Update your Video Driver?
I'm trying here!
* Grazie
