Bulk adding titles
COW Forums : VEGAS Pro
jithendria kumar aravamudhan
Bulk adding titles
on Feb 8, 2016 at 7:34:51 am
Is there a way to attach a title video to a bulk of other videos in Vegas?
Wayne Waag
Re: Bulk adding titles
on Feb 8, 2016 at 4:40:58 pm
Interesting question. Using just Vegas, I don't think so. However, if you have Vegasaur, it's quite easy. Using Transcoder, add videos, select rendering template, and output location. Then under the BOLT tab, you can add a leader or trailer. In your case, you would add a leader. Using this approach, there is no need to actually import your videos directly into Vegas. If you don't have Vegasaur, I believe they still have a 30 day free trial. Good luck.
wwaag
on Feb 8, 2016 at 6:46:30 pm
Thanks a lot Wayne. Will definitely try this.
John Rofrano
on Feb 8, 2016 at 6:00:07 pm
[jithendria kumar aravamudhan] "Is there a way to attach a title video to a bulk of other videos in Vegas?"
Vegas Pro Production Assistant was designed specifically for this kind of batch workflow. You can very easily set up a template with the title video and a slug to represent the video. Then point it at a bunch of videos and it will substitute your video for the slug and render in multiple formats, with each video you give it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
on Feb 8, 2016 at 6:47:16 pm
Thanks a lot John.
