Vegasaur is causing Vegas to crash!
COW Forums : VEGAS Pro
Gabriel Meono
on Feb 5, 2016 at 10:39:02 pm
Vegasaur 2.4 causes Vegas 13 to crash while importing any media, this does happen by dragging the media in the timeline or by browsing it from Vegas.
As soon an item is imported or placed directly on the timeline Vegas will crash immediately.
If Vegasaur is uninstalled Vegas will continue to work uninterruptedly.
Is there a way to fix this?
Gabriel Meono
Re: Vegasaur is causing Vegas to crash!
on Feb 6, 2016 at 1:43:31 am
Bump.
Wayne Waag
on Feb 6, 2016 at 3:10:10 am
I've never had (or heard of) a problem like that with Vegasaur. Since removing and re-installing Vegasaur doesn't work, have you tried a re-install of Vegas. Just make sure you save all of your presets. Do you have any other plug-ins installed? When did your problem start? Have you installed any other programs recently that make use of .Net? You might want to download and install the latest version from Microsoft. Just make sure you create a restore point. In any case, suggest you email Vegasaur and report your problem. In the past, they have always been very responsive.
wwaag
Gabriel Meono
on Feb 6, 2016 at 4:33:39 am
Hi Wayne, sorry for confusing you. Vegas works perfectly without Vegasaur, as soon as it's installed the program crashes when importing media into Vegas, every single time. Without Vegasaur Vegas behaves correctly and without crashes. Therefore Vegasaur is causing the crashes.
Steve Rhoden
on Feb 6, 2016 at 10:39:00 am
Well then contact Vegasaur and let them know of the problem
you are having, and be detailed in your explanation.
They are normally prompt in resolving their software issues.
Ive never ever experienced or heard of anyone having this sort
of problem with Vegasaur as you described.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Gabriel Meono
on Feb 6, 2016 at 2:57:06 pm
Vegasaur support replied with this:
We never heard of this problem before.
Is there an error message?
Currently we have no solution, sorry.
I will make a video and attach the screenshot when the problem occurs.
Gabriel Meono
on Feb 6, 2016 at 3:35:36 pm
I was able to fix the problem by clicking on "Remove All Unused Media From Project". There was a lot of garbage in the project, somehow Vegasaur didn't like that.
Thank you!
Steve Rhoden
on Feb 6, 2016 at 11:29:03 pm
ok...
