Rendering with or without GPU -> Strange pixel effect
COW Forums : VEGAS Pro
lucas pelus
on Jan 25, 2016 at 8:28:53 pm
Hello,
I have a strange pixel effect on a render :
I got rush from a gopro hero3+ silver -> 1080p50
The project is 1080p50, the render is 720p25
If I render with CPU and GPU (CUDA) there is some strange picel in the sky. Check at 00:11 - 00:14 (top right). password is test
https://vimeo.com/150973510
When I render with CPU only, everything is normal
https://vimeo.com/152924365
I remember on another computer with a ATI GPU, rendering with the GPU was better than without.
I similar problem than here but in the other way...
Cannnot understand why.
John Rofrano
Re: Rendering with or without GPU -> Strange pixel effect
on Jan 25, 2016 at 9:16:58 pm
Rendering glitches with GPU turned on happens sometimes. It could be a particular GPU driver version. Sometimes updating your drivers or actually downgrading them will produce different results. CPU rendering is usually consistent and without errors.
~jr
http://www.johnrofrano.com
http://www.vasst.com
