When I make a slo-mo clip, why are parts of the clip cut off?
COW Forums : VEGAS Pro
John Lee
on Jan 25, 2016 at 3:58:37 am
I've always wondered this. When I want to do a slo-mo clip, I usually just selected the playback rate to be .5 instead of 1.0.
That slow the clip fine, but it seems like part of the end of the clip is gone. Is that normal? Should I be doing something else to make a slo-mo clip?
Thanks.
John Lee
Re: When I make a slo-mo clip, why are parts of the clip cut off?
on Jan 25, 2016 at 4:25:02 am
I forgot to the mention that the audio plays back at full speed, not half speed, for some reason.
Graham Bernard
on Jan 25, 2016 at 9:58:09 am
I've rarely used that method, I use either stretch, velocity envelop or TWIXTOR. All this require to increase the actual EVENT length to get ALL the clip. Are you doing this?
* Grazie
John Lee
on Jan 25, 2016 at 1:19:42 pm
I posted too soon instead of researching it more. After I posted, I figured out that I should do the click+drag on the clip instead.
Thanks.
Graham Bernard
on Jan 25, 2016 at 1:31:49 pm
No worries. Thanks for the update.
* Grazie
John Lee
on Jan 25, 2016 at 11:05:55 pm
Quick question. The reason why I initially did the playback rate thing is that I want to precisely dictate the revised speed of the clip. Selecting click+drag is somewhat imprecise.
Is there any way I can correctly input exactly how fast/slow I want a revised clip to play? Thanks.
Mike Kujbida
on Jan 25, 2016 at 11:11:49 pm
Place a marker at the beginning of the clip and another one at where you want the end to be. Ctrl+drag the clip.to this new length. Done.
John Lee
on Jan 25, 2016 at 11:15:57 pm
Thank you for taking the time. But that's my question. Instead of eyeballing how long I want it to me, is there a way for me to make the clip playbacking twice as slow, twice as fast, 1/3 as fast, etc? I would like to be able to input it rather than dragging it imprecisely.
Mike Kujbida
on Jan 26, 2016 at 12:41:31 am
I'm not expecting you to eyeball it but you will have to do some basic math :)
To find the length of the original event (what Vegas calls a clip), double click it and look down in the box at the (as I recall) bottom right of the screen. I'm not at my computer right now so this is from memory. That box will show you the event length.
For this example we'll assume a framerate of 60i and an even numbered length.
Let's say the first event is 06:20 (seconds and frames) long and you want to slow it down by /2. The new length will be 6:20 x 2 = 12:40 = 15:10.
Enter this length into the same box. The highlighted event will now be this new length.
Ctrl+drag it out to the new length.
It works the same if you were to shorten it. All you have to is some simple math, enter that value into the box and adjust accordingly.
I sure hope that makes sense to you :)
