Sync rectangle with text
COW Forums : VEGAS Pro
Gennady Gaidukevich
on Jan 12, 2016 at 4:05:24 pm
https://images.creativecow.net/306096/img-2016-01-12-18-04-35.png
Hi. I need advice. How to sync moving text with rectangle? What I do is create layer with flying text, then add new layer, insert Solid Color, use Pan/Crop, copy and paste even attributes from layer with moving text. But problem is copies not only the movement of text but also its` size. As a result I cant adjust size of black layer
Graham Bernard
Re: Sync rectangle with text
on Jan 12, 2016 at 6:59:55 pm
If you don't need to have black and text move separately, add Black Background to Text Media Evet and then Mask in Pan/Crop. Then use Track Motion to move whole Even where you want it. Or have I misunderstood?
* Grazie
John Rofrano
on Jan 13, 2016 at 1:24:57 am
You can create a Parent Track and make the Text and Background tracks a Child Track and then use Parent Motion to move both child tracks in unison.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Graham Bernard
on Jan 13, 2016 at 8:35:12 am
Here's my explanation of using my approach and the much loved "simple-stick" - as per Stevie Jobs:
Result:
Layout ONE Track of Black BG and Text over the video:
I'm using the Controls for the Background in T&T to supply the Black Background:
* Grazie
