Right arrow key not working.
COW Forums : VEGAS Pro
Simon Rasmussen
on Jan 12, 2016 at 2:26:59 pm
Hello,
I just discovered a problem with my right arrow key in Sony Vegas Pro 13.0. You know when you press the arrow keys, it moves frame by frame. Well my left key is working perfectly fine, while the right key works for a frame or two, then stops.
I read a previous post on here where the exact same problem was the case, but the only tip was to press "alt" which toggles the keyframe lock, this is not the case.
Every reply will be appreciated!
Graham Bernard
Re: ight arrow key not working.
on Jan 12, 2016 at 3:25:19 pm
Save Project, close all and reboot PC. Any good?
* Grazie
