[SOLVED] Unable to import mp4 into Sony Vegas Pro 11/12/13, and can't play on QuickTime
COW Forums : VEGAS Pro
John Ryan Fajardo
on Jan 10, 2016 at 5:46:32 am
SOLUTION:
Use QuickTime version 7.6.5
Hi, after searching through the internets for days to find a solution, I come here. I use Bandicam to record my videos, and I usually had no problems importing them into Sony Vegas. What's wrong?
Actions that might relate to the cause:
- Uninstalled and reinstalled QuickTime (which also upgraded it, I normally don't upgrade it, just iTunes.)
- GPU update
And yes, I run Sony Vegas as administrator.
It can open WMV, but not MP4 or AVI. I get these messages,
MP4:
AVI:
The videos play fine on VLC and WMP, but NOT QuickTime.
On QuickTime, I get the message:
Here is the file information using MediaInfo:
General
Complete name : G:\Game vids\Hearthstone\Classic pack openings\bandicam 0126.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (mp41)
File size : 14.7 MiB
Duration : 18s 500ms
Overall bit rate mode : Variable
Overall bit rate : 6 679 Kbps
Encoded date : UTC 2015-12-30 20:51:33
Tagged date : UTC 2015-12-30 20:51:33
Writing application : BandiMp4Muxer 1.0
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Bit rate mode : Variable
Bit rate : 6 478 Kbps
Maximum bit rate : 42.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 15.838 fps
Minimum frame rate : 0.480 fps
Maximum frame rate : 60.060 fps
Original frame rate : 60.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.197
Stream size : 14.3 MiB (97%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 18s 497ms
Duration_LastFrame : 1ms
Bit rate : 192 Kbps
Maximum bit rate : 272 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Stream size : 441 KiB (3%)
Language : English
I hope you can help solve my problem. I appreciate your time and effort to do so. Thank you ~
Here are my Bandicam settings, just in case (although these have always stayed the same). I never use AVI (because of filesize), only to test.
MP4 Settings:
AVI Settings:
Graham Bernard
Re: Unable to import mp4 into Sony Vegas Pro 11/12/13, and can't play on QuickTime
on Jan 10, 2016 at 8:15:08 am
Update QT and Reboot PC.
* Grazie
John Ryan Fajardo
on Jan 10, 2016 at 10:17:35 pm
I have the latest version of QuickTime (version 7.7.9), as I mentioned earlier. Still won't open.
John Ryan Fajardo
on Jan 10, 2016 at 11:58:33 pm
UPDATE:
I recorded using these Bandicam settings, and was able to import them. The difference here is that I used a Motion-JPEG codec for the AVI, instead of the Xvid.
General
Complete name : G:\Game vids\Hearthstone Classic Pack openings\bandicam 0148.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 817 KiB
Duration : 144ms
Overall bit rate : 46.5 Mbps
Writing application : BandiAviMuxer 1.0
Video
Format : JPEG
Codec ID : MJPG
Duration : 142ms
Bit rate : 46.8 Mbps
Frame rate : 120.000 (24/30) fps
Minimum frame rate : 24.000 fps
Maximum frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.188
Stream size : 809 KiB (99%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Duration : 144ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Stream size : 3.38 KiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (2.83 video frames)
Although it's great this one works, I still prefer using MP4 with my original settings as the file size difference is huge. Just thought this new information might help.
Do I need to install a certain codec or something?
John Ryan Fajardo
on Jan 11, 2016 at 3:37:09 am
SOLVED! See the first post (now edited) for the solution!
