Anchor background text?
COW Forums : VEGAS Pro
Evan Lindman
on Jan 2, 2016 at 5:43:26 pm
Hey, fellas!
I am working on a video project for church, what I want to do is take that "Investigate Jesus" logo and put it in the background, so it isn't covering up their faces.
So when you look at it-it would appear as if there was an actual banner hanging in the background. I know this has been done before with text.
Can anyone give me any direction?
Thanks!!
John Rofrano
Re: Anchor background text?
on Jan 2, 2016 at 7:15:01 pm
[Evan Lindman] "... what I want to do is take that "Investigate Jesus" logo and put it in the background, so it isn't covering up their faces."
To do that you would need to key out the background and just leave the subjects at the table so that you could insert the banner behind them. Unfortunately you didn't shoot against a green screen and there is too much white in the foreground to use a luma key. What you need is a traveling matte which which would be very hard to do with Vegas Pro. You would have to painstakingly draw a mask around each subject and animate it frame by frame. It's possible if you have the time and patience. After Effects has some rotoscoping capabilities that could help if you have AE.
I'd say you're out of luck unless you want to try and create a mask by hand. Next time, shoot against a green screen if you know you want to change the background.
~jr
http://www.johnrofrano.com
http://www.vasst.com
