Render without losing quality ?
COW Forums : VEGAS Pro
Darryn Carroll
on Dec 17, 2015 at 2:53:41 am
I have a crazy workflow so please bear with me. I am editing a multicam project using Sony Movie Studio which is fairly close to Vegas for basic edits. I am making simple edits, cuts and envelopes. Next step is to render and use a different NLE to finish. This means the final video will be rendered once by Sony and a second time with different NLE. Is there a recommended format to render too from Sony to keep first render as close to original quality as possible?
John Rofrano
Re: Render without losing quality ?
on Dec 17, 2015 at 4:44:22 am
[Darryn Carroll] "Is there a recommended format to render too from Sony to keep first render as close to original quality as possible?"
The recommendation is to use a Digital Intermediary when rendering across your production pipeline. CineForm AVI has long been the favorite DI format for Vegas Pro. Avid DNxHD is also a Digital Intermediary in a QuickTime MOV container. This would be a great format if the other NLE was on a Mac. Some people use Sony MXF HD422 50Mbps because it retains it's quality well, but Sony MXF is not a DI.
You also have to consider what formats the other NLE can ingest.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Darryn Carroll
on Dec 17, 2015 at 10:11:38 am
Thanks John, those formats look way over my head :)
It keeps selecting the format below but I assume I will lose quality? This is the original file format as well. I am not a Mac, a PC running Videostudiopro X8
John Rofrano
on Dec 17, 2015 at 1:45:28 pm
Rendering out to AVCHD should be fine. One or two renders are not going to lose any visible quality as long as you are using a high bit rate which the AVCHD @ 16Mbps does.
~jr
