Problem with Sony Vegas
COW Forums : VEGAS Pro
Isabela Moraes
on Dec 15, 2015 at 4:03:48 pm
I'm showing you these images because I don't even know what's going on, so try to make it clear for me pls
http://imgur.com/29CsjZB pic in sony vegas with cookie cutter effect (cut away all but section)
And how can you see, there's this rectangle and circle instead of only one circle and black background
http://imgur.com/awpfGUS and this same picture with cookie cutter effect but with its position changed.
Help me pls!!! I've tried everything I could, unistalled, reinstalled, etc... D:
Mark Barton
Re: Problem with Sony Vegas
on Dec 17, 2015 at 7:34:18 pm
I'm thinking the video driver is messing up your preview. Have you tried turning off GPU acceleration under Preferences/Video? If that works then try finding a different driver (newer or older) for your video card. If you bypass the Cookie Cutter effect, does the preview show the original media properly in the preview window (no strange rectangles)?
