"The external media file is corrupt or otherwise invalid" SVP11/BCC8
COW Forums : VEGAS Pro
Neil Napp
on Dec 5, 2015 at 5:03:56 am
Are any of you using BCC effects w/ the Beat Reactor option?
I've exported aif audio from Vegas, converted to aif in Sound Forge, tried an online converter, same problem. Theses aif's will play in other s/w, but Beat Reactor throws this error. One time, it actually worked, and I could render am mp4 w/ the effect, but then the error again, same everything.
Any thoughts?
John Rofrano
Re: "The external media file is corrupt or otherwise invalid" SVP11/BCC8
on Dec 5, 2015 at 2:04:57 pm
[Neil Napp] "I've exported aif audio from Vegas, converted to aif in Sound Forge, tried an online converter, same problem. "
I'm not sure why you're having a problem because the default templates in Vegas Pro for AIFF work perfectly. Watch this video that I made for Boris TV on the BeatReactor and at 2:08 I show you how I create AIF files right from within Vegas Pro:
See if you are doing something different.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Neil Napp
on Dec 5, 2015 at 2:26:12 pm
Thanks, John. Actually, your video is the one I followed when first trying this. If you read down the comments on youtube, you'll see someone w/ the same problem 6 months ago, with no answer.
John Rofrano
on Dec 5, 2015 at 2:39:04 pm
If you created the file the same way that I did, and since the error is coming from BCC and not Vegas Pro, I would post this to the Boris FX forum here at the COW and see what they think. Perhaps you can send the file to Boris and they can see why it's being rejected.
~jr
