How to stop apostrophes disappearing when bringing Word script into vast caption assistant on Vegas pro 13?
COW Forums : VEGAS Pro
Amanda Duffield
on Nov 26, 2015 at 8:22:20 am
I can only see an option to bring in text from the clipboard .otherwise I would re-save my script in notepad as 'unicode'. Am I missing something?
Steve Rhoden
Re: How to stop apostrophes disappearing when bringing Word script into vast caption assistant on Vegas pro 13?
on Nov 26, 2015 at 10:26:15 am
That's just how it is, apostrophes is always missing whenever you copy
and paste from a Word document, Notepad, PDF or WordPad into Vegas in
whatever way.
Only solution i know of, is to simply go thru and make the corrections
when copied.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
John Rofrano
on Nov 27, 2015 at 3:40:03 pm
As you have seen, Word does not use apostrophes or quotes. It uses an alternate italic character that does not translate so you need to convert your text to unicode to get back the original apostrophe and quote characters. This is a Word problem not a Vegas Pro problem. If you want an apostrophe in your document you need to tell Word to stop changing them. (I have no idea how to do this which is why I use Notepad instead which doesn't have this nasty behavior)
~jr
http://www.johnrofrano.com
http://www.vasst.com
Steve Rhoden
on Nov 28, 2015 at 6:43:18 am
Well doing some re-checking, Notepad is indeed the exception!
