Project Won't Open
COW Forums : VEGAS Pro
John Perez
Project Won't Open
on Nov 15, 2015 at 6:04:05 pm
My project is freezing when building peaks or importing nested timelines. I moved the nested timelines so the timeline opened but when I tried to replace with nests in a different location it froze. Any ideas on how to resolve this?
As always thanks so much to you guys...Johnny In Orlando
Steve Rhoden
Re: Project Won't Open
on Nov 16, 2015 at 12:18:13 pm
Your nested files are what is causing Vegas to keep freezing, when its on
the timeline in a project.
I no longer work with Nested Vegas files anymore because of this happening
sometimes. So what you do John is simply render out your individual nested
files that are included in a project and let them retain the original names, then load your project with those new rendered files instead.... You will
have no more issues.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Wayne Waag
on Nov 17, 2015 at 1:53:05 am
Agree with Steve. I gave up on nested projects a long time ago as well. For one thing, they always dramatically increased the render time for me. Aside from rendering out an intermediate for each project as Steve suggested there are a couple of other options. If you have Vegasaur, you can stitch together individual projects for a final render using their Transcoder. Another option (the one I use most often) is to simply create a final project from your individual sub-projects by copying and pasting each sub-project into the final project. This does require a common track layout for your individual projects.
wwaag
Steve Rhoden
on Nov 17, 2015 at 11:53:12 am
"Another option (the one I use most often) is to simply create a final project from your individual sub-projects by copying and pasting each sub-project into the final project."
Yes, Yes, that is another very good option Wayne!
Steve Rhoden
on Nov 25, 2015 at 2:54:17 pm
Any Luck?
