Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
COW Forums : VEGAS Pro
Adrian Komorek
on Nov 14, 2015 at 1:08:53 pm
I just uphraded my from Windows 7 Pro to Windows 10 Pro and Sony Vegas 13 Pro woulden't open anymore, I trieded ALL solutions outthere, updating drivers, disabling graphic card, running as a admin, cahing combality, both, it just woulden't open, it seems to crash when it's loading up Installing DirectX plugs-ins.
Extra Information
File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 290) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\WINDOWS\SYSTEM32\vorbis.acm
Fault Address: 0x00007FF9B8241F4F
Fault Offset: 0x0000000000001F4F
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 290) 64-bit
Process Description: Vegas Pro
John Rofrano
Re: Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
on Nov 14, 2015 at 6:08:55 pm
[Adrian Komorek] " Process Version: Version 13.0 (Build 290) 64-bit"
Try updating to Build 453 and see if it works.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Steve Rhoden
on Nov 25, 2015 at 12:51:54 am
Because you not using the latest version of Vegas 13 optimized for
Windows 10. Download version 453 from the Sony Creative website...
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Rob Lindsay
on Mar 1, 2018 at 2:52:22 am
I do use ver 453, and it still freezes on opening when it hits the Directx part of the start up. This last time it took 5 attempts. Froze at Directx each time and each time I had to Crl alt del and start over.
is there a fix?
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU
John Rofrano
on Mar 3, 2018 at 12:07:44 am
I'm guessing it's a graphics driver problem. Try updating to the latest drivers for your card. If you are at the latest drivers, try downgrading to older drivers.
~jr
http://www.vasstsoftware.com
Geoff Candy
on Mar 5, 2018 at 9:56:31 pm
Version 453 is the last version from Magix and does not contain dolby AC Pro. If you are currently using the last version from Sony then carefully copy out the dolby pro plugin folder & copy it in to the newer V13.
More info is available on the magix vegas forum. Search missing 'dolby pro'
G
Rob Lindsay
on Mar 5, 2018 at 11:42:17 pm
Sorry, why would Dolby AC pro help with a freeze issue around DirectX initialization?
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU
Rob Lindsay
on Mar 12, 2018 at 2:45:10 am
Installed ver 545 and it still freezes at Initializing DirectX.
I'm at a loss at what to do.
Vegas 13.453
Dell Windows 10
Intel6700 quad CPU
16 Gigs RAM
3 Gig GPU
Geoff Candy
on Mar 12, 2018 at 12:37:22 pm
I seem to recall that trying to install VP13 onto W10 I had problems with the installation. Initially I gave up on VP and loaded DVDA as I normally edit in Edius. DVDA loaded and installed some .net components. On trying to install VP13 again it went in smoothly. VP13 last Sony version.
I can understand your frustration.
