Region Naming Script Needed
COW Forums : VEGAS Pro
Jay Mitchell
on Oct 31, 2015 at 8:19:27 pm
Are there any scripts that will automate region naming?
I need a script that will see all of the regions that I make on the timeline and give them a sequential number name that I can then use Vegasuar to burn in as a watermark.
Jay
Jay Mitchell
FootageWorks.com
ActionStockPhoto.com
Jay Mitchell
Re: Region Naming Script Needed
on Oct 31, 2015 at 8:56:45 pm
Here is an example of what I need with the first region being named D875-C-001 and thereafter sequential like below.
D875-C-001, D875-C-002, D875-C-003, etc...
I am repeatedly creating several hundred regions from long files that I can't break up and it is laborious to name each one manually.
Jay Mitchell
FootageWorks.com
Wayne Waag
on Oct 31, 2015 at 9:19:00 pm
Just posted a reply on the Vegas Pro forum.
wwaag
Jay Mitchell
on Oct 31, 2015 at 10:34:29 pm
Saw it! Thank you for helping.
Jay Mitchell
on Nov 1, 2015 at 12:54:14 am
How do you select "all events"?
I do have "entire project" and "at events" selected as in your photo.
Wayne Waag
on Nov 1, 2015 at 1:02:31 am
Just select the events on the timeline. E.g. Select first event on timeline, right-click and select Select Events to End. Then all events will be highlighted. Then go to markers window, configure the regions as shown, and then select apply on top of window.
wwaag
Jay Mitchell
on Nov 1, 2015 at 1:09:30 am
Duh... I should have known that. So easy a cave man can do it :)
The Vegasaur naming did not like my naming convention D329-C-001.
It is not picking up the -C-
But, did do D329-1 on the first region.
I will try all of this again with "Select All" and see if it works...
Thanks Wayne - - Much appreciated
Jay
Wayne Waag
on Nov 1, 2015 at 1:20:58 am
Just a thought. It may treat the - as the end of base name. Try changing your - to _ and see if that works. I'm not at my editing PC at the moment, so I can't try it. I'm dealing with trick or treaters at the moment.
wwaag
Jay Mitchell
on Nov 1, 2015 at 1:38:40 am
I cannot get more than the first region to be selected.
Wayne Waag
on Nov 1, 2015 at 4:06:58 am
Back to my editing PC. Works perfectly here. Will try to assist you in AM.
wwaag
Wayne Waag
on Nov 1, 2015 at 3:37:00 pm
I also tried this in V10 and it works the same. Here are a couple of screen shots. First, make sure that your timeline events are selected. Note that they have all turned blue. Then configure your create marker window as shown. It is the exact same as I posted earlier.
Once you hit the apply button, the timeline will look like this.
It really sounds like all of you your timeline events are not being selected, just the first one. If you are still having problems, then upload a screen shot of your timeline and also your marker creation window.
wwaag
Jay Mitchell
on Nov 1, 2015 at 7:31:04 pm
When I right click Region #1 the context menu has Go To, Go to End, Select Region, Rename and Delete. There is no option to Select Events to End. But, If I right click in the timeline itself I do see Select Events to End.
In your image it shows what appears to be each of the regions highlighting separately. Al that I have been able to do is to get the entire track to highlight from beginning to end, including the spaces between regions.
Even if I "Select All" nothing happens....
My number is 213 four hundred 6397
jay
Wayne Waag
on Nov 1, 2015 at 8:17:10 pm
I guess I'm confused. As an example of your timeline, do you have say 200 5 sec events or do you have one 1000 sec long event that you want to break up into 200 5 sec intervals? I was assuming that you already had multiple events. Please clarify. As stated, a screen shot of your timeline would be most useful.
wwaag
Jay Mitchell
on Nov 1, 2015 at 8:45:12 pm
Here is the workflow. I start with a 3 hour clip on the timeline. I then scrub through making region pairs as needed. Making In-Out-R precisely where needed. And not based on intervals. I usually end up with 200-400 of these Regions across the entire timeline. So, what I have is all of the green region flag pairs from 1-300 etc...
The purpose of giving the regions serial number names is so that I can use Vegasaur Timeline Text Tools to add those serial number names as overlays, before rendering...
Aleksey Tarasov
on Nov 1, 2015 at 9:54:20 pm
Jay, this will do the trick:
This function creates a new region with a new name in place of the existing region.
In fact, this is the renaming of the existing regions....
Jay Mitchell
on Nov 1, 2015 at 10:15:45 pm
Aleksey,
I will try that. Is there any way to have the sequence numbers start at 001,002,003 etc... instead of a single digit?
Jay
Jay Mitchell
on Nov 1, 2015 at 10:31:46 pm
Aleksey,
Thank you very much..... It worked perfectly !!!
Now, if only there is a way to have the 3 digit sequence numbers from 1-99
I love Vegasaur!
Thanks again,
Jay
Aleksey Tarasov
on Nov 1, 2015 at 10:38:28 pm
> "Is there any way to have the sequence numbers start at 001,002,003 etc... instead of a single digit?"
No, Markers tool has no such functionality.
There is another way, a bit more complicated:
1. Prepare a text file with your labels, like this:
D875-C-001
D875-C-002
D875-C-003
D875-C-004
...etc.
D875-C-300
You can easily prepare this list in Excel/Open Office etc.
2. Copy this text to clipboard and paste it in Edit Details window
Jay Mitchell
on Nov 1, 2015 at 11:00:38 pm
That's Great! And will try it.
Otherwise I will just rename 1-99 in the edit details pane...
Wayne Waag
on Nov 1, 2015 at 9:25:57 pm
Apparently, you hit the solution button and your last post was deleted, or maybe you've solved the problem? Too bad you hadn't posted your workflow earlier. So basically, you've already defined your regions. Is it OK to simply delete footage not within those regions from the timeline? If so, then it will be pretty simple. Under the Tool tab in the Marker window, tick Keep/Delete Events and choose Keep Inside Regions for selected tracks. Now your track will be broken down into events. Then close the gaps for the selected tracks (1-click command). Back to the Marker window, delete regions. Then create the regions using the procedure I first outlined with the names. To try this, I would first do a Save As to a new Vegas project file. In the event things go awry, you can always get back to your original work.
wwaag
Jay Mitchell
on Nov 1, 2015 at 9:41:58 pm
Thanks Wayne,
I tried uploading images of my timeline, but got flagged for moderator review.
Wayne Waag
on Nov 1, 2015 at 10:39:34 pm
Jay,
This is even easier if you have Excel. Open a new worksheet and in first cell type in your first name. E.g. D875-C-001. Then place the cursor at the lower right position of that cell until you see a + sign appear. Then simply drag down however many regions you have. I chose 40. Here is the screen shot.
Now simply Copy (Ctrl-C). Return to Vegas to your project where you have already defined your regions. Enter Alt-6, Edit details and select show Regions. It will look something like this.
Select all the under the column Name, and then simply Paste (Ctrl-V). The region names from your Excel Worksheet will now be shown. Just another way to do it.
wwaag
Jay Mitchell
on Nov 1, 2015 at 10:34:37 pm
Wayne,
Aleksey's method worked perfectly, except for the single digit numbering from 1-99.
I hope that can be adjusted.
I want to thank you again for all of your help.
I really appreciate it.
Jay
Wayne Waag
on Nov 2, 2015 at 3:17:54 am
[Jay]
Glad you finally have it sorted out.
[Aleksey]
That was a very useful tip about the renaming of regions, something I didn't know about--I'm sure because I've never had a need to do it, right (LOL). I'm always somewhat amazed about the depth of Vegasaur with its many intricacies. The thing I enjoy most about participating here is that I learn something useful most everyday.
That said, I do wish that Vegasaur had an option for padding its numbers.
wwaag
