Normalize question
COW Forums : VEGAS Pro
Stephen Whiteman
Normalize question
on Oct 29, 2015 at 10:07:10 pm
For some reason, my vegas started acting really weird the other day. When I try and record, the sound is almost silent. I have to manually normalize the sound track to get it back to normal. It didn't used to be like this. I don't know what I did and I can't figure out how to fix it.
I used to be able to hit record and talk and that was that. Now I have to normalize every single audio recording. Anyone have any idea to why this is?
Wayne Waag
Re: Normalize question
on Oct 30, 2015 at 3:00:00 am
First thing to do is look at the recording levels in windows. On the little speaker icon in the task bar, right click and then select Recording Devices. For your input device (microphone), select properties and then the levels tab. If low, then raise to see if that makes a difference in Vegas. When recording voice, the levels should be peaking somewhere between 0 and 6 db using the vu-meter for the selected audio track.
wwaag
Steve Rhoden
on Oct 30, 2015 at 6:32:02 pm
Probably you have accidentally lowered your Recording Levels in your
Audio properties. Double check those properties and make sure that all
levels are raised and where they should be.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
